GregLast
Your video sounds to me like an engine running with the spark fully retarded at low throttle. Does the engine speed change when you advance the spark? What happens when it is running like shown in the video and you press the accelerator pedal?
The video is of the car running with the spark lever up and the throttle lever up as well. When I moved the spark lever to advance the timing, it started to struggle. When I give it a little gas, it's struggles. I'm running it pretty lean on the GAV.
I've run the battery down cranking it tonight. Going to let it charge and try again tomorrow.
