TradModelA
Hello I have an all original Tudor with a zenith- 2 carb, the issue is engine runs like it's rich all the time but the inside adjustment is all the way lean (to the right or clockwise) it makes the engine shake and spudder when not under load. Under load is ok, only seems to run good when you turn the gas tank valve off and right before it runs out of gas it idles up and runs smoothly. What could this be? Thanks
