bcatcmc
There comes a time when you realise that self help is just not gonna cut it, that time is here. With regards to my failure to overcome a rich idle with my 1940 Merc engine rebuild there are a couple of options, go cap in hand to Mr Stromberg Support or throw it at the Barn door and see what you fellas think.
Some background info , this is a long term project ,final assembly this year engine bored 060” over , Offy heads, new valve gear and springs new Offy intake with 2 new Stromberg 97 carbs. Electronic ign. home grown headers ect.
I will post up a series of numbered photos with descriptions here , most of this info gathered today. Did a compression test (hot ). 135 psi all round , I am 2400 feet ASL so a bit over 2” of Vac to be added to gage readings, the ignition set at 6 Deg BTDC, the spark looks puny but jumps 1/2 “ lead to plug, new NGK B-4L plugs gapped at .025 “ ( swapped over from B-6L ), all 4 mixture screws seated, the fuel bowl levels are both right. Engine starts up within 2-3 revs most times.
Photo 1 shows general set up.
Photo 2 shows some of test gear 3” Anemometer for balancing airflow, fuel bowl level indicators , spark plug tester.
Photo 3. Shows vac gage jumping around a little at 15 “ ( 17 “ ) 465 rpm popping a bit at exhaust, idle not smooth.
Photo 4 Shows 1 “ gain on vac gage ( now steady ) still popping a bit , still not smooth, 680 RPM
Photo 5 Shows Offenhauser exhaust smoke indicator after a 1 sec. blip on throttle off idle .
Photo 6. Shows fuel bowl level indicator, basically eliminating fuel pump pressure concerns.
Photo 7 Shows matt black painted ? Spark plugs sooty but not wet. ( usually after 3-4 min. Run time
A couple of other things, if I deliberately run it out of fuel the last 20 seconds before it conks out , the idle gets quite smooth, the revs increase slightly and the vac gage goes up about 2 “ . I have tried lifting 1 carb at a time , removing linkage and sliding a blanking shim under , still idles rich. Adjusting idle mix screws in or out doesn`t effect vac gage or sound much at all. Painted around carb. bases with oil looking for vac leak only made a mess. No fuel visible down throttle bores. Still runs rich with gravity feed , 20 “ head, fuel bowl level dropped to 5/8”
The only good thing to come of all this , I have fumigated most spiders and bugs in the workshop and my reproductive health is of no concern anymore . Any help would be appreciated.
