Running Board Trim - '28-'29
Special Coupe Frank
My '28 Special Coupe has repro running boards on it ( don't know whose ).
They have the zinc trim along the long sides, but none across the ends...
I have some original '29 running boards with all trim intact, and it appears that the end pieces were secured with tubular rivets ?
At any rate, is there a source for the end-trim for '28-'29 boards ?
Thanks !
SC Frank
I had enough long peices to do a set for my coupe but the end peices were shot.
So I utilized a few of the broken, long outside strips and took them to a metal fabricator. Here they flatened those strips, cut them to match the configuration of the original end strips and then formed those to size.
Then I drilled the holes in the end strips and secured them to the ends of the running boards with, as you say, tube rivets.
Pluck
Do you have the contact info for BoB Burdick. I've never heard of him.
Here you go: ZINC RUNNING BOARD TRIM
1. No known website: Bob Burdick (949) 310-4088 (California)
Go to the above STICKY and find more useful Model A vendors.
Pluck
