running board brackets
dirt t
My son and I are building a 1930 CCPU. We built the frame using different
diagrams available on the net. It was difficult to find correct dimensions.
That's a story in it's self. You would think in modern time there would be an accurate blueprint of a model A frame. Where we need help is the location (elevation) of the running board bracket. Could someone give us the distance from the top of the frame rail to the center of the top mounting hole.
Thank you for your time
Terry aka dirt t
Terry aka dirt t
Here's the best I could do with the measurements. This is the location of the rear bracket on the drivers side. I inverted the pictures the second timed I tried to load them and they still post upside down. Download them then rotate them the right side up on your computer. Hope this helps you!
