Rumble Seat Lid Installation - 30 Coupe
AGBill
I am about to install the rumble seat lid on my coupe. The lid was previously installed as a rumble seat lid and all the parts are original. The triangular shaped hinges are currently installed on the inside of the lid.
What is the easiest way to complete the installation? I was thinking of installing the hinge bolt and the square washers and the bracket on the lid before trying to install it? This way you would only have to install the two mounting bolts to the body support bracket.
Has anyone tried to install it this way?
If not, what is the easiest way to finish the installation?
AGBill
Here is how I have done them:
Mount the hinges to the lid.
Mount the pivot brackets to the vertical brace. Bolts loose.
Place painting sticks along each side in the rain gutters and across the front to establish spacing all around.
Set the lid in place.
From inside the cab (seat removed) install the pivot bolts, shims, spacers as required to allow tightening the pivot bolts and the pivot bracket bolts WITHOUT DISTURBING the spacing established by the paint sticks.
Luck.
After mounting you will likely needed some adjustment. I was fortunate enough to have enough bodies to place one inside under the lid with one on either side of and outside the car. That way as the outside guys made adjustments the inside fellow can adjust inside when needed and snug up bolts.
I just tried the paint stick idea.....worked great got my previously crooked lid to lie even, thanks for the suggestion!
Just a follow-up to my original question regarding the installation of a rumble seat lid on a 30 Coupe...
I loosely installed the lid in the opening, but my side clearances were too small for the paint stick idea. After some struggle, I finally loosely installed the hinge bolt, the two square washers, the lock washer and the nut. You are doing this by feel since you cannot see the nut end of the bolt because it is hidden by the hat section mounting bracket.
Before tightening the bolts, I got a small scissor lift jack and a block of wood and carefully jacked up the inside of the lid out of the side rain gutters and aligned everything square and level. I then tightened all the loose bolts.
The only remaining problem is the fact that the repro rubber bumpers at the top of the lid are too tall. I will replace them with some shorter ones to align the top of the lid to the body properly.
I did this installation myself, but much patience is required, especially with installing the hinge bolts!
AG Bill
I know this is an old thread, but I hope my question is relevant! Which part of the hinge/bolt/washers is supposed to move? Also, for my 68B the proper placement seems to be in the upper/forward portion of the bracket hole. I can't seem to get the nut tight enough to prevent the bolt from 'travelling' lower into the hole. The movement seems to be associated with the washers rotating when the lid is opened or closed.
Any advice? Thanks!
After reading the above posts it brings back memories of my efforts when I was installing my coupe's rumble lid. It wasn't fun. I wonder how it was done on the assembly line? Maybe it was installed before the body was placed on the frame.
When I did my coupe it wes freshly painted and not wanting to mess it up we used the engine hoist to hang the lid in place while the bolts were installed. Short ratchet strap with rubber coated hooks using the holes in the inner pannel made it simple and held the lid in an open position.
Then for the adjustment, no simple way for that. just got to go slow.
A short addition to post #8 is that all bodies were basically complete at the time of the body drop onto the frame so deck lids would be installed during body build.
