Ralph 31 Model A
I have a 1931 Model A roadster. When ever I the rumble seat, the back of the seat loose... What is the proper way the install the back rest of the seat ?
There should be a pair of clips that are attached to the top of the seat back/cushion, and a corresponding slot to accept these on the upper inside of the rumble lid itself. There should also be either an elongated portion of the seat frame or other attaching clip that would allow for a screw (and washer) to secure the bottom portion of the cushion to the lower portion of the lid once the top of the cushion has been dropped into place. The clips on replacement springs are not nearly as sturdy as those on original seat springs. Good luck on these - its not a difficult challenge so much as being nimble enough to screw the lower portion of the seat spring into place.
