Rubber protection against suns radiation
bikemaniac
Hi,
In terms of rubber window seals that are exposed to the suns UV radiation. Is there a way to do a long term protection of installed and exposed rubber seals? Currently I have some rubber seals that are 40 years old and I would like them to last another 40 years without them cracking and deteriorating. Imagine the harsh sun in Arizona or the Southwest.
Is there a product I can smear on the seals that does not require multiple applications each year? A truly long lasting product.
Lucas
I use 303 Protectant. I couldn't tell you how long it works. I use it on my top and running boards to hopefully prolong their life.
529869
Years ago there was a product used to protect rubber seals etc. I checked and it is still being manufactured in the states by American Grease, Ru Glyde is the product name. It is mainly used when installing tires, as bead lube . Price is approx,$20 a gallon . Google this and find an auto store near you.
Don S
The biggest killer is Ultra Violet. Shop for a product that will protect from UV rays. The 303 does do that and it doesn't leave a glossy dust attracting film like ArmorAll.
My wife's Corvette, they use dilectric grease on the window seals. Especially the rear hatch window.
Napa Sil-Glyde, 765-1351, Claims it will do what you need it for. For use on belts, brake pads, V-belts, weather stripping, window channels, speedometer cables, hood strips and pads and rubber gaskets, as the back panel on the tube I have states.
