Rpu cab dimensions 28/29 and 30/31
poweredbylincoln
I would like to see if anyone might have the dimensions for a 28/29 rpu cab?
Planning on putting it together. But have two passenger side doors. Willing to turn one into a drivers side doors. And no rear panel. Willing to make that too
If I might be able to get a bunch of dimensions from a cab to build
Mine from? :)
And also would like to get dimensions for a 30/31 rpu cab as well.
I have a cowl and doors and a new back in 3 pieces. But need to put the rear panel together with the right dimensions.
So would love to get dimensions from a 30/31 to do so
Final 2 questions. Are closed cab seat springs the same as in rpu's?
And subfloors same or different?
Thank you guys in advance :D
Hi BL: Do you have 1928 - 29 :
roadster doors ?
RPU subfloor ?
RPU 1/4 panels ?
1/4 panel to back panel top braces ?
back panel to subfloor braces ?
Seat frame ?
I know anything can be done, but I would sell / trade one of your RH doors for a LH door, before I would attempt to change a RH door to a LH door.
Gary in MN
roadster doors ?
RPU subfloor ?
RPU 1/4 panels ?
Seat frame ?
Gary in MN
Gary,
I have a 28/29 I am trying to put together a 28/29 from the pieces i have. i dont have any of the panels. except.
cowl,2 passenger doors. right and left hand 1/4 panels. I don't have the rear panel or a driver door.No subfloor or braces.
Thank you!! for the picture that'll work great. Would you happen to have the same picture for a 30/31 rpu?
I am trying to put a 30/31 rpu together as well. But I have cowls,doors, and a backpiece in 3 pieces. needs to be cut and welded together to the right dimension
