Took the car out for its weekly winter exercise, speed was 58 mph at 2400 rpms, is that about normal for a 3:54 in the rear?
I installed the 3:54, but, I have 16 inch wheels.It depends on wheel diameter. Assuming from your user name that it is a 1929 model.
If you have 21" wheels with a dia of approx 30" your speedometer should show close to 62 mph for a 3.54 rear.
If a 30-31 with 19" wheels, your speedometer would be closer to 60 mph with a 3.54 rear.
If you are reading 58 mph I would believe you have a standard 3.78 rear and not a 3.54. Why do you think you have a 3.54 rear? Did you rebuild and change ring & pinion?
Thanks GRutterThat makes more sense.
My chart shows a rolling circumference for a "typical" 16" tire to be 89.10", which would put you at 57.1 MPH at 2400 RPM with a 3.54 rear. With the variation in tires, you could be spot on at 58
