Afordman31
How to restore your Model A volume 7 has a article by Michael Pawelek, Fulshear, Texas. Page three.
The article states to shim the rotor so it would be parallel to the distributor contact point, he said .035. I made shims for mine and it raised the rotor but the tip would hit under the distributor contact point.
The article said "do not try to bend the tip up as this will either cause it to break or will cause the rotor tip to not be parallel to the contact point."
Has anyone tried to bend theirs or grind the rotor tip shorter or used shims to be parallel and be able to get the .035 gap? I took the shims out and have been running the gap larger than .035.
