Well - I used two engine stands. The rear of the frame I made a bar to go between the frame rails and bolted on the restating portion of the one engine stand. Then I put a 2x6 board from floor to ceiling, drilling a hole for the round end for the round bar that would go into the engine stand and put a bolt through the hole in it to keep it home. For the front, did the same thing but this time used the engine stand on that end, making @feet” for the engine stand to bring the frame up to a height that would clear the floor.
If you would like more info, send me a pm with your email address and I will send you pictures…
