Update again thanks for all the help. Could not work on it last night had to take wife out for anniversary. Tonight and to answer a few questions I am not running thermostat. I am on my second new water pump. Ok bought a vac gauge hooked up to manifold bounced like crazy form 0-17. I could get it to somewhat stabilize at 16 at about 3000 rpm. Hooked it inline to vac line off carb to dist reading was about 4 went to zero when motor rpm increased. Next took Walts suggestion brought problem cyl no 2 to tdc applied air had air flow out carb Pulled intake exhaust a tight feeler gauge at .016. Intake could not get .007 feeler under it thinking I got in a hurry and did not butt grind. I think my next step I'd to pull head and redo intake unless anyone thinks I am off track. Thinking the lack of spark advance is causing overheating? Not sure if the valve issue could be causing this. Open for ideas and suggestions Oh I also filled cooling system with vinegar.
