roof/top questions
Willynch
What is the exterior top made from and how best to care for it. Is it vinyl? What was the original material?
The inside top material in my Tudor needs to be replaced. How can I learn to do that? Can I replace just the inside top material without replacing the material that lines the sides adjoining the top?
Thanks for advice and guidance.
Í just wash the top of my tudor when I wash the car. The headliner is not too hard to install if you follow directions from the vendors. You will have to remove the panels which cover the edges of the headliner material but shouldn't have to replace them unless they are in bad condition.
I got my headliner from LB. They were very helpful, and it was a relatively easy install.
Ken
