Years ago I replaced the bows in my 1930 Murray Town Sedan. I assume the top material has been removed. The bows dropped in and they were notched to fit the side main supports. They were secured by a wood screw at each end. Perhaps someone with a Briggs body can confirm they are the same. Ed
that would solve the issue, but will it support the long term pressure of the roof fabric?Cut a slot in the middle of the rib from the top left yo right about 2 inches long and 1/4" wide. Cut the rib in half in the middle of the slot. Install the 2 halves and use a 1/4" wide piece of wood to secure the 2 pieces together. Glue with wood glue.
Bob
Top bows on my 30 Murray were not mortised but dropped into a slot milled into the side rail held with one wood screw.
