Rolling Chassis 41 Ford Pickup
FwJ1941
Osceola
Iowa
Price
In add
For Sale: 1941 Ford 1/2 Ton Pickup Rolling Chassis. Rear End Gear Ratio is believed to be 3:78 with a stamping of “9 34” just below pinion. Tires P205/75 R15 Tread is good with date stamping 33 & 34 of 2015. Included with the frame / suspension is the gas tank, 4 Speed transmission (granny gear) steering wheel, column with switch & the steering gear box. Also the inner fender V shaped bracket that bolts to the frame. Heater assembly that did not appear to have any leakage and with working fan.
You will note steel plates welded to frame just before rear wheels.
Asking $1000 for all of the above in a complete package. Please advise me with any questions that you may have. Cell # 641-340-1508. Thank you!
I failed to mention that I do have a spare tire & wheel assembly that is included with this package.
Thanks
Frank Jones
