Rods
Mike Mayer
I have just picked up a8BA Block with a mercury crank this motor is apart . Included in the mix is a full set of 8BA pistons and rods . my Question is are they compatible ? Thank you in advance.
Kahuna has it. The wrist pin is located in a different position for the 8BA type rods they share so they will have proper piston to cylinder head clearance.
The 1CM would indicate the crank that came out for the Merc-O-Matic in the 1951 model year. The earlier ones weren't marked. On them, a person had to go by the characteristics of the clean out bores and the width of the counterweight cheeks or the throw of the crank pins if you have a way to check them.
