Rods & mains do not need cotter pins or other devices. I use ARP 12-point nuts on the rods. For mains I ran out of my Cat long-nuts so started using Model A lug nuts that I machine off the taper, and use a hard washer under them. They look cool, have a lot of threads and are of good material. I was a mechanic for a lot of years and never saw a rod nut that had loosened and the cotter pin was holding it on.
Thanks! Just ordered a free catalogue!I use the Brattons #8950 set sucessfully for the mains. They are a touch longer than stock and have more threads. For rods I got some specialty self locking nuts from Coast Fabrication, what they call Jetnuts, used in racing applications among other things. http://www.coastfab.com/index.html Their catalogue has all kinds of nuts and bolts and the people will talk to you.
Is there something better out there after nearly 80 years?
The first model "a" engine I took apart had a strange size of nuts and bolts on the rods. I can not remember but they were like between my 1/2" and 9/16" wrenches. I had my dad's old Ray socket set. The sockets were in thirty seconds .He liked working on Model "a" engines.
I use to be with him when he was working on mom's model "a". He always said they are going to make these again someday. He was kind of right but I do not think he would have bought a Shay.
I've been curious why the A has cotter pins on these yet modern engines don't need them. Whats different? Lock washers?
All old engines, Mains and rods used, castle nuts, Lock wires, lock plates, nut, with tin lock nuts like Chevy's ect. Many of the old engines now, have lock washers, as a replacement to keys. The easiest way to solve a lock problem now, if you don't want to use Keys, go to an engine rebuilder of modern engines and get a modern rod, or main lock nut. You have to watch what you buy for lock nuts, at a hardware store as MANY will tear up the threads, on a rod, after years of over torquing. A good Rod, or Main from an engine is very hard, and will laugh at a file. Thanks Herm.
