Dirtslinger
I have another question, I've got my bottom end together on my 8ba, I noticed that there's very little end play on the rod journal's, is there a number that I should be looking for? Possibly use a feel gauge to check?
BTW, having larger clearances (on the higher side of the spec Tony posted) is not a bad thing for any higher performance flathead. It helps in letting more oil out of the bearing (faster) and cooling it.
That makes sense. Im getting about .009 on mine, it will have to do.
Sometimes a tight reading is caused by the fillet radius on the crankshaft being large. This causes the rod bearings to push towards the center of the rod journal. When that happens the connecting rod bearing edges that faces the crankshaft radius needs to be chamfered doing this now gives more clearance between the rods. Sometimes a large radius happens when the crank rod journal is ground undersize. And can also happen when your using an aftermarket crankshaft especially if its a specialty crankshaft made for higher performance out puts.
Ronnieroadter.
Great point from Ronnieroadster. I find this very common on the stroker cranks I have ground so now always check this as some bearings are way too tight at radius.
After further consideration, Im thinking I may need to chamfer these rod bearings. It still seems quite tight in there. The other option would be a different set of rod bearings that are more narrow?
