Jon
Removed my oil pan to change the gasket and check the bearing clearances. Noticed there is a lot of play in rod bearings side to side. I measured, .015", .020", .022", .022". Car ran good, no noises. Are these bad enough that I should fix or can I run without any problems? I have yet to check bearing clearances, need to go to a meeting tonight so had to stop looking. I also found a piece of babbit in the oil pan. Haven't found where that came from yet.
From what the previous owner told me it has about 35,000 miles since rebuild. I've put the last 22,600 on it, average 2,500 per year.
