Cape Codder
I am in the process of tightening the caps on mains / rods with the motor in the car.
I have read in Les Andrews book to torque the Rod nuts to 35 ft. lbs. while Brattons catalog says 45 ft. lbs. Which is correct? ALSO when torqueing the the nuts which way do you go if the holes don't line up for the cotter pin, loosen or tighten? By the way Les Andrews book does not say anything about installing cotter pins after the cap is installed and torqued.
Thanks for your time.
Cape Codder
Cape Codder
