Johnnydidd
Repainting engine rockers covers are red is this the right or should they be blue? Did they build only 312 Mercurys in 1956
I believe that is correct. But it's been a little while since then and the engine in the car now could easily have been changed.... Did they build only 312 Mercurys in 1956
Lots of 50's y-blocks are red/orange, esp in the 'Ford' cars. Mercury had their own color schemes for several years, gold and yellow are also possibilities. Do a google search for "images 1956 Mercury" and see what you find, until others here chime in.Repainting engine rockers covers are red is this the right or should they be blue?
How it looked before rebuild & paint. Perhaps not an exact match but very close:
The engine pictured here appears to be from a '55 Mercury (292) based on the yellow color and the fact that is had core plugs if the front and back of the headsSal
raceron1120, is that a caddy air cleaner and is it regular size or 7/8 size, I would like to get one. very nice engine, thanks for sharing[/QUOTE
It's either Cadillac or Olds, can't remember which. But is an original, not a repop. Reworked from oil bath to now takes a paper filter element.
raceron1120 does it clear the distributor or did you have to modify it, Speedway has them in std or 7/8 size.
