Roadster Pick-up Door
flybob08
I have an open hole in the top of the door and one on the upper trailing part of the door around the lock area. I have filled them with rubber plugs on an interim basis. Is there a specific part that should go in either or both holes. The holes are on both the right and left side of the truck.
Thanks, as always
Bob
I believe the top one is for the side curtain rod and the side one for one of the snap inserts for the curtain.
post above...CRS has it right, top hole is for the side curtain rod, side facing hole is for the side curtain itself.
The original side curtain snaps are unique, and used to be very hard to find. I don’t know if they’ve been reproduced.
