Bill Goddard
I have a rear end ring gear that will not drop over the mounting diameter on the carriage casting that holds the spider gears. The ring I.D.is about 4.125" dia and the carriage is w/in .001" of that dia. I have tried heating the ring in an oven and it did drop on but I ran out of time fooling with the 9 bolts. It seems there is only one way the ring will go on and I haven't found it yet. I will try the heat method again tomorrow but I was wondering if I could have a machine shop trim a little off the carriage O.D. to allow assy and fitting of bolts at room temp. I have been told the ring should drop into place and it doesn't. Any thoughts from the experts out there? Thanks Bill G
