I think the b6a-3254 part number is for LHD and the c or b at the end us for the 3 or 2 sector shaft gear. I can't seem to find either the shaft by itself or the gear and shaft together.... I have found the RHD gear at Dennis carpenters but I need the shaft!!!
Norm give Cusso Bill a ring. He should be able to help. I think Joblot Auto have the worms and sector gears. It is easy to press new worm on existing shaft. Getting a complete shaft from the US will be in excess of $100 post.
Thank Rick, Cusso Bill doesn't do the shaft...I can get a LHD worm / shaft from the states for $150 delivered...but would like to confirm the part number so that I get the correct length (I don't have one to measure) there seem to be a few different lengths according to RCM's post. (I can also buy the RHD worm drive)
Norm you don't need the shaft, all you need is the worm gear and the sector gear if worn. If Bill can supply get them from him, they will be right. You need a RHD worm as our box is a mirror version of the US. A LHD box will not fit an Oz car as the shaft is on the opposite side of the worm therefore the worm is different.
You can simply get the gear pressed of the shaft and a new one pressed on. The sector gear you simply grind the staking off the shaft and fit a new one and lock with an arc weld tack. There are two different worm and sector kits. 2 or 3 teeth. There are also two different sector shaft seals. Bill you will tell you what you need.
I Don't have a shaft, I currently have a 16-1 mustang box fitted, I have a box and sector shaft gear and can rebuild it if I have a shaft... I want to get back to the 25-1 ratio, I can get the RHD worm gear.
