RHD parts
Anything in particular you are looking for? I know I sold a steering box,and I may still have a bellhousing and pedals.I would have to look.I know I have a throttle pedal setup.It clamps to the steering column,and I was going to use it to operate a horn or whistle.I'm in Epping,20 miles straight down 125,south of Rochester.
In addition to what Keith said, there differences in the brake cross shaft, the bell housing, pedals, inlet manifold, pitman arm. steering arms on the front hubs, wiring loom, tail light bracket etc and the rear vision mirror and wiper are mounted in a different position. Then there is the fuel tank
I have some of those bits but freight and tariffs would kill any deal.
You'll also need the bell crank that goes on the manifold and rods the right length for the distributor (not available). Then there is the mechanism that bolts to the back of the block a bit like your throttle fitting to get from the starter button to the starter itself.
