john charlton
I fitted a regular Zenith to my RHD phaeton and found the choke lever fouled the two tooth steering box .An easy fix I just bent the area with the hole in it 45 degrees and problem fixed . I looked at English Kayce carbs and they do not have the extended lever with hole . I checked an English parts book ( 1931) and it shows A 9548 with no extension with the hole .I have an English instruction book which shows the lever with the hole this also shows the 7 tooth steering box so the lever does not foul the steering box .A later instruction book the lever with extension and hole is not shown this shows the 2 tooth steering box so RHD with a 2 tooth you dont get the lever with the hole in the end . So it seems with RHD and the 2 tooth box you cannot run a wire through the rad when you hand crank as it has the pre Dec 1928 lever . Just wondered why Ford did not bend the lever to clear the box or only not done in England .RHD drive in Australia any thoughts on this conundrum ???
John in RHD Suffolk County England .
