HOTROD_WILLIE Senior Member Nov 9, 2018 #1 I have old Rex temperature gauge. I need fitting to attach to Model A Ford block. Thanks for the help. Attachments IMG_3687.jpg 47.9 KB · Views: 31
HOTROD_WILLIE Senior Member Nov 9, 2018 #2 Here is the fitting end. Attachments IMG_3686.jpg 19.4 KB · Views: 41
Flathead Well-known member Nov 9, 2018 #3 Probably could use a Stewart Warner adapter fitting, easier to find at a parts store. Use a radiator hose nipple with a pipe threaded hole.
HOTROD_WILLIE Senior Member Nov 9, 2018 #4 Flathead said: Probably could use a Stewart Warner adapter fitting, easier to find at a parts store. Use a radiator hose nipple with a pipe threaded hole. Click to expand... Already try that. Thanks
T talwrench Member Nov 9, 2018 #5 If my memory is not failing i think I found the matching fitting at a NAPA store
Chris Haynes Well-known member Nov 9, 2018 #6 Most likely it attaches to a water outlet and not the block. I bout my outlet from Snyder's. https://www.snydersantiqueauto.com/drilled-water-outlet
