Paul from Maine
Just installed a reproduction Rex-a-co oil pressure Gauge this afternoon. How accurate are they? It seemed to respond to changing engine rpms very slowly. It would show 4 lbs when cruising and then at a stop sign continue to show 4 lbs while idling. Then when I accelerateded away from the stop, it would drop to zero, even though the engine rpm had increased significantly. Then suddeny, when I had been cruising for a minute or two, it would jump back up to 4 lbs. Is this normal? Could it be my oil pump or just a sticky gauge?
