Glyn Farrell
New member
Hi
To attain a reverse flow engine, if the method used is to change to a Windsor chain and gearset to run the camshaft clockwise, thus the oil pump and distributor drives must rotate clockwise instead of the usual anticlockwise.
Question: does oil pump still function properly and the distributor also??
Is there any detrimental effect on the camshaft or oil pump gears???
Does the timing gear/chain set need to be set a number of degrees advanced or retarded???
Any modifications required for the surfaces of the pistons or valves or exhaust passages like ceramic coating to diminish heat effect on the 'new' exhaust passages, valve seats etc.
Very interested in any response and any other potential glitches of the conversion.
Could Les Schubert or Wayne Atkinson comment??
Regards
Glyn F
Regards
Glyn F
