1Metalbender
I have seen the "reverse flow" concept applied in a couple of ways to our Flatheads. In the very earliest example, I remember, a single barrel carb was mounted at each of the standard exhaust locations(6 carbs) and special headers made on top of the engine for exhaust outlets. The guys were happy with their work and garnered mucho attention. BUT, they were 20 MPH slower than our conventional arranged Flathead.
Simply doing a flow test will explain why. As bad as the conventional intake flow is, the exhaust is slightly worse. Putting the inlet charge through the conventional exhaust ports would only serve to reduce potential power.
However, there is some potential power improvement when revised ports are bored into a new location at the top of the block. This improvement is a result of flows being increased.
The overheating "problem" has already been addressed in this thread and becomes irrelevant unless reasonable measures are not maintained.
That was the answer I was looking for...I'm never offended by guys that know what their talking about so no worries there...the reason for the thread was to gain some insight as to why they did it since I couldn't find on it other than it was done to help with overheating problems...no other information came with the search...have to admit running the exhaust out the top would save me a lot of work on running a exhaust but a caddy is definitely out of the question! A ford needs a ford in it...way too many of them with sbc's now as it is...might consider a hemi but those are really hard to find and extremely expensive when you do
