Restored hydraulic shocks
We should have the rebuilt originals for your model a. If not, we can build up the correct set, unless you need an early 28, correct set, or the late 1931s
If you are replacing a set of copious leaking units I will have to see them, probably would need changing out to fix heavy wear.
Good shocks will dramatically improve the handling. They are a critical part of the suspension system. Original, refurbished shocks on hand. Contact me for a price, and availability. The replacement clones will leak. And may not be rebuildable. The model a did not come from the factory with tubular shocks. Originally sold with Houdaille shocks.
