Restore Steering Wheel
Bill in SoCal
The picture is of the steering wheel from my 1930 coupe. The wheel has been washed with Simple Green, and has several hairline cracks. What should I use to clean, shine and preserve the wheel. Is there a common way to restore the wheel?
Thanks Paul. I look at the EV8 board, and they had good information on repairing cracks with PC-7. Once I have done that - what should I use to clean and seal the wheel (If I understand the postings, you do not want the wheel to be too shinny).
A fellow I know swears that black primer is identical to the correct finish. You could shoot a test piece to compare to your preference of what it should look like.
After repairing a steering wheel, I have been pleased with the finish that PPG DP-90 leaves on the surface. The finish appears to be "original" to most Model A enthusiasts. Gar Williams
