Restoration Qs... trunk / rumble
d.j. moordigian
Is there a piece of wood, on either side, that runs front to back, to support
the card board? This would be midway up and bolted to the upright support.
I think it would look like a " lathing strip ". Thanks
Is this what you are looking for... If not have have more photos that I can post
I would amigine that they all ran in the same direction, from point A to point B within the compartment no matter what model.
Pluck
Dennis..I don't have those strips of tin, do they bolt to the inside of the rain gutter?
What year , I don't think the body style makes a difference ? Boy, it does make sense
now. Dudley
Dudley I'm going by memory ha I think they went between the gutter and T strip they came out of a 28-29 coupe to hold the cardboard at the top. Hung a inch or so below the gutter.
Dennis...My car was never apart ( but now in the proses ) and I have owned it about 45 yrs. I will look tonight and let you know. Thanks
Dennis..
If you look at Doug Cox car , there is a small tap.
Doug..
Nice rumble area, btw
Here are a few more photos of the rumble area after body work and epoxy primer...
Dennis...My tin strips are bolted to the inside, closest to the wheel wells, didn't know
they were there.
Doug...28-29 VS 30-31, same thing only slightly different, I now know were I am going.
Nice tin work( repop?), the wheel wells look like they were a work out.
Thanks for all the help, Dudley
If you are not too far along, the here is something to consider. For sound deadening, and you might say water proofing as well, I added some inexpensive “fixes.” I first cut templates out of Tar paper that fit over the rear tire well and all along the rear quarter. I then spread a very thick application of roofing tar (about a ¼ inch thick) over the entire area that would be under the tar paper template. I then installed the tar paper, which acts to hold the roofing tar in place until it sets. The scrap piece of tar paper I got from a buddy and the roofing tar came from the home center in gallon cans for just a few bucks. I also did the same for the front kick panels. Just an idea and it is a lot cheaper than some of the other methods.
These are all the articles related to the rumble seat which have been printed up in Model A News, The Restorer and Model A Times:
DECK—REAR
A-41440: Door (deck) Assembly (without Rumble Seat)
“Deck Lid Comparison: 28-29 and 30-31”: MAN/28/6/12-13 (1981)**5
Also see: A-52435
A-41510: Plug (deck drain trough) (with rumble seat)
“More Finishing Touches”: TR/31/4/18-19 (1986)*4
A-41514: Aluminum Rear Deck Guides for Trunk and Rumble Seat
“On the Hill”: MAN/55/6/18-19 (2008)
A-41515: Aluminum Rear Deck Guides for Trunk and Rumble Seat
A-41516: Aluminum Rear Deck Guides for Trunk and Rumble Seat
A-41530: Deck Lid Support Arm
“Bratton’s Antique Auto…Quality”: MAT/6/1/27 (2010)
A-41563: Step (deck) on rear fender and bumper (with rumble seat)
“The Step Plates”: MAN/22/6/16-17 (1975)**3
“On the Road”: MAN/37/6/13 (1990)**7
“On the Hill…A-41563 Step Plate (deck) and Pad on Rear Fender”: MAN/56/2/34-35 (2009)
“Pictorially Yours…1928 (Location of Early Plate)”: TR/13/4/27 (1968)
“TIP…Fender Step Plate Location”: TR/24/1/20 (1979)
A-41568: Deck Step Fender Pad
A-??????: Key for rumble/trunk
“On the Road”: MAN/32/6/12 (1985)
“Keying Your Model A”: MAN/56/2/26-30 (2009)
A-41605-F, G: Handle (deck door locking) Assembly
“On the Road”: MAN/32/6/10 (1985) **6
A-41655: Seat (rumble) with fittings
“Upholstery, Upholstery, What’s Wrong with My Upholstery?”: MAN/36/5/18-19 (1989)**7
A-41663: Step (deck) on rear fender and bumper (with rumble seat)
A-41664-AR: Cardboard (deck side) R. H. – 40-A (with rumble seat)
“On the Road”: MAN/39/5/12 (1992)
A-41665-AR: Cardboard (deck side) L. H. -- 40-A (with rumble seat)
“On the Road”: MAN/39/5/12 (1992)**7
A-41664-AR: Cardboard (deck side) R.H. (with rumble seat)…(40-A)
“Schematic Drawing and Dimensions”: MAN/14/6/16-17 (1967)
A-41665-AR: Cardboard (deck side) L.H. (with rumble seat)…(40-A)
A-41664-B, C: Cardboard (deck side) R.H. (with rumble seat)…(40-B: Std., and De L.)
“Schematic Drawing and Dimensions”: MAN/15/2/18-19 (1968)
A-41665-B, C: Cardboard (deck side) L.H. (with rumble seat)…(40-B: Std., and De L.)
A-52435: Door (deck) Assembly (with Rumble Seat)
Also see: A-41440
“LETTER…Inside of Deck Lid”: TR/52/5/5 (2008)
“Removing the Rumble from a Rumble Lid”: TR/54/6/20-23 (2010)
A-52664-AR: Cardboard (deck side) R.H. (with rumble seat)…(45-A, 49-A, 50-A and 60-A)
A-52665-AR: Cardboard (deck side) L.H. (with rumble seat)…(45-A, 49-A, 50-A, and 60-A)
A-52664-C: Cardboard (deck side) R.H. (with rumble seat)…(45-B Std., and 50-B)
A-52665-C; Cardboard (deck side) L.H. (with rumble seat)…(45-B Std., and 50-B)
A-52664-D: Cardboard (deck side) R.H. (with rumble seat)…(45-B De L.)
A-52665-D: Cardboard (deck side) L.H. (with rumble seat)…(45-B De L.)
A-52694: Cushion (deck seat back) assembly
“Upholstery, Upholstery, what’s Wrong with My Upholstery?”: MAN/36/5/18-19 (1989)
A-52659: Cushion (deck seat) assembly
“Upholstery, Upholstery, what’s Wrong with MY Upholstery?”: MAN/36/5/18-19 (1989)
A-70664-AR: Cardboard (deck side) R.H. (used with adjustable seat)…(68-B)
A-70665-AR: Cardboard (deck side) L.H. (used with adjustable seat)…(68-B)
A-70664-B: Cardboard (deck side) R.H. (68-C)
A-70665-B: Cardboard (deck side) L.H. (68-C)
DECK LID HANDLES
“Model A Bright Work”: MAN/28/4/4-6 (1981)
“Restoration of the Model A Door Handle and Deck Lid Handle”: TR/37/1/32-34 (1992)
“Door and Deck Lid Handles”: TR/45/6/16-21 (2001)*8
KEYS AND LOCKS
“Model A Ignition Locks”: MAN/36/6/13-15 (1989)**7
“Model A Keys and Locks”: TR/30/4/10-15 (1985)*4
RUMBLE SEAT
“How to Install a Rumble Seat”: MAN/10/2/???? (1963)
“Rumble Seat Conversion”: MAN/15/6/6-8 (1968)**2
“TIP…For Rumble Seat Conversion”: MAN/16/4/22-23 (1969)**2
“The TUXAWAY Overhead cover for Rumble seat”: TR/1/6/51 (1957)
“The TUXAWAY Rumble Seat Top”: TR/10/6/12-16 (1966)
“Rumble Seat Installation”: TR/20/1/18 (1975)*3
“TIP…Rumble Seat Brackets”: TR/21/4/5 (1976)*3
“Installing A Rumble Seat”: TR/34/5/16-18 (1990)
“McLean’s Rumble Seat Top (Pamphlet)”: TR/45/3/14 (2000)
“Rumble Seat Belt Installation”: MAT/3/1/20 (2007)
OTHER ARTICLES ON THE “DECK—REAR”
“Pictorially Yours…1928”: TR/13/4/27 (1968)
After three heavy coats of epoxy primer, I figured the inside was good enough. I made a steel square tubing sub frame to support the body allowing me to easily get to every nook and cranny. So no I did not put the roofing tar over bare metal. A good catch if I was not clear on my other post,, thanks
I have a late '31 coupe that does not show any indication of the wood strips ever being installed. The vertical steel bars have the proper holes for the wood strip. This car has the trunk lid, not the rumbleseat. Were the strips used as late as '31, and were they used with the trunk lid arrangement? Thanks.
