wbedwards - I just pulled both resistors out and checked them with my digital meter - both read 6.3 ohms. They were both strapped to the steering column which should have been able to absorb some heat. That said, when I turned the car off, both resistors were too hot to touch - but so was any other metal within a few inches of the engine!
Dog - that's an interesting point. I initially thought the same thing, based on my electronics course from long ago that taught me that the total resistance of a circuit consisting of two resistances in parallel was less than the smaller of the two. And that adding resistance in series increased the total resistance of the circuit. But I installed them in parallel as advised by the tech fellow at a well-known parts emporium - and also as I've seen illustrated on the internet. And we all know that the internet is never wrong.
Thanks, both of you, for your ideas!
Now....after I pulled the resistors out of the car for testing, the flash rate on both sides was slower than during the today's tour. Interestingly, the left side is noticeably slower than the right side. (This corresponds to what I saw after installing the turn signal system with the LED tail lights. I had installed the resistors to slow the flash rate down more. This worked initially but then the flash rates became way too fast during the tour.) It's possible that I have a different wattage bulb in the left vs right front units. I will check this tomorrow.
So....should the resistors be installed in series or parallel? Are there any other ideas out there that would explain this odd set of results? Thanks guys!
Dave
p.s. Just saw the replies from Big Hammer and J Witt. I am very confused about the parallel vs series approach. Isn't the formula for resistances in parallel: 1/R(t) = 1/R(1) + 1/R(2) = R(1)xR(2)/(R(1)+R(2))? And doesn't this mean that the combined load if wired in parallel will be smaller than the smaller resistance? And isn't this exactly the opposite of what we are trying to accomplish?
What am I missing? Thanks!
