zuburg
I am in the process of trying to re-assemble my 1956 T-bird after nearly 5 years since disassembly and my memory of where some things go is failing me. I just found an odd looking part that I don’t remember ever seeing before. I found out it was the resistor for the coil. Looking at some pictures of exploded parts, I believe it is attached to the coil bracket.
Do I have it oriented correctly in the picture? I attached it with the connectors facing the firewall. The screws on the coil are marked Dist and Battery. I assume the battery terminal is the “+”? In the picture, you can see a short red wire on the top connector of the resistor. Based on my notes, I believe this wire should attach to the screw labeled “Dist”? Is this correct? What wire should be attached to the bottom connector on the resistor?
Added the picture I forgot.
Thanks
Thanks
