Resistor for coil on 1956 Thunderbird
zuburg
I am in the process of trying to re-assemble my 1956 T-bird after nearly 5 years since disassembly and my memory of where some things go is failing me. I just found an odd looking part that I don’t remember ever seeing before. I found out it was the resistor for the coil. Looking at some pictures of exploded parts, I believe it is attached to the coil bracket.
Do I have it oriented correctly in the picture? I attached it with the connectors facing the firewall. The screws on the coil are marked Dist and Battery. I assume the battery terminal is the “+”? In the picture, you can see a short red wire on the top connector of the resistor. Based on my notes, I believe this wire should attach to the screw labeled “Dist”? Is this correct? What wire should be attached to the bottom connector on the resistor?
Added the picture I forgot.
Thanks
Here is a wiring diagram example.
Which way the ballast resistor terminals face depends on its mounting bracket and the position of the coil.
Do I have it oriented correctly in the picture? I attached it with the connectors facing the firewall. The screws on the coil are marked Dist and Battery. I assume the battery terminal is the “+” ? In the picture, you can see a short red wire on the top connector of the resistor. Based on my notes, I believe this wire should attach to the screw labeled “Dist”? Is this correct? What wire should be attached to the bottom connector on the resistor?
Thanks
The wire from your ignition switch goes to one end of the resistor. The other end of the resistor goes to the "+" , or battery side of the coil. The "-", or "dist" side of the coil goes to the distributor.
I thought I saw a picture with the resister attached as your photo shows (connectors pointing towards the drivers side, not the firewall). Is it held in place by one of the mounting bolts? I was able to attach it to the mounting bracket using the screw that tightens the ring part of the bracket. In hind sight, I think I should have just attached it using one of the bolts that attaches the coil to the block.
Not sure which ballast resistor you have but if you got it from a 'T-bird' supplier, yes chances are good the base of its bracket mounts to one of the two bolts that also holds the coil bracket to the intake manifold.
My mistake - the connectors do point to the left fender. The second picture shows the original type resistor, which is still available from the Tbird parts suppliers.
