If I disconnect all radiator hoses/pipe from the engine and allow all the coolant to drain out normally, how much if any water will still be in the engine head or block and would this amount be enough to cause freeze damage over the winter? I will not be able to reassemble the radiator and hoses until spring so the option to add antifreeze is not really practical. But if there is no water in the block then I would not have to worry about it.
Thanks
Dave
Thanks
Dave
