Here in the Northwest, a bent up model A hood will still cost one about $100, I have found that it takes a lot of work to get rumpled up hood straightened out again. For me, a new hood was the most affordable way out.just curious why you wouldnt install an original?
They are very affordable in nice condition.
Rootlieb makes a quality hood. The only thing I would suggest if you do buy a new hood is to take a file or dremel and cut back the metal near the hinge area. The two top hood pieces fit together too tightly here without enough gap when the hood is lifted up. If you have any thickness of paint (primer+ sealer + enamel paint) here, it will be scraped off as the hood is opened past the hinge. I doubt that even lacquer will escape this fate.
Marshall
