I think the correspondence I received from a fellow A Barner to resolve the problem I encountered in mounting repo running boards is worthy of being shared. I am certain others will probably have the same problem. I am taking the liberty of sending a copy of what transpired between me and Tom Moniz who I feel got to the bottom of my problem.
Thanks again Tom.
Lou M.
Subject: Fw: running boards
Date: October 4, 2010 3:04:44 PM EDT
To: loumo@verizon.net
Lou
I just went through this with mine
I used a big 2 in pipe and gently tweaked them to fit
just slip it over the end
first mount your fenders ,then get the exact measurement from the fender to the first brace,tweak it to fit,
then tweak the rear one to get your 28 1/8 in
no model As were unique
they all used the same running boards,and braces
if they got in a wreck from the front,the fenders would get pushed back and would push the running boards back,bending the brackets
tom moniz
----- Original Message ----- From: "Lou Morongell" <loumo@verizon.net>
To: "mot @ The Ford Barn" <68c@frontiernet.net>
Sent: Monday, October 04, 2010 11:49 AM
Subject: Re: running boards
Hi Tom,
Thanks for your interest.
I measured with a steel straight edge ruler and got exactly 28 inches on centers between the two upper-most rivets at the top where they are attached to the frame.
The spacing of the holes in the RB support brackets - where the RB's get attached with the 4 special bolts - all measure 27 and 3/4 inches between centers
Now what do I do?
I am starting to think that the RB's are not the problem, but something with the support brackets may need tweaking, although I can't understand how they could change they are so solidly attached to the frame.
Thanks,
Lou M.
On Oct 4, 2010, at 10:55 AM, mot @ The Ford Barn wrote:
This is a message from mot at The Ford Barn ( http:// www.fordbarn.com/forum/index.php ). The The Ford Barn owners cannot accept any responsibility for the contents of the email.
To email mot, you can use this online form:
http://www.fordbarn.com/forum/sendmessage.php?do=mailmember&u=1131
OR, by email:
mailto:68c@frontiernet.net
This is the message:
what is your measurement between the center rivet on the frame?
it should be the same as the spacing for the running boards
tom
Thanks again Tom.
Lou M.
Lou
tom moniz
Hi Tom,
Now what do I do?
Thanks,
Lou M.
OR, by email:
tom
