From what I understand front door window replacement is pretty straight forward, but what about the rear side windows??? Heard they can be a pain ?? Any tips or tricks to make this easy????
It is a pain. You have to unscrew the inside metal support panel and pull it away from the body. Install your weatherstripping and slide the glass in from the bottom. It's a struggle, and you'll learn a lot about it when you remove the old glass.
The doors are pretty direct and easy.
Also, if you do an advanced search here, there are some earlier (and probably better) descriptions on this topic.
