Replacing Water Pumps on a stock '49 Ford
pebo va
When removing the two bolts from the engine mount, the engine moved forward about 1/8 inch or so. The other 4 bolts on the pump came out just fine. Now the new pump holes for the engine mount don't line up. Will jacking up the engine under the oil pan fix that? If not, what is the solution?
