I need to replace the speedometer drive gear on the end of the drive shaft. I have pulled the rear end assembly from the universal joint, per MODEL A FORD MECHANICS HANDBOOK. Also, I have removed the snap ring and the drive gear. Having the rear end pulled, I would like to replace the roller bearing, sleeve, grease seal and thrust washer.
Do I need to pull the drive shaft from the torque tube in order to remove/insert the roller bearing and related parts? The HANDBOOK seems to imply I should be able to pull the parts from the universal joint end of the drive shaft?
Thanks.
Thanks.
