Tinker
So I'm replacing my cracked exhaust manifold with a snyder manifold. Car is a 29'
My check list:
Bolt exhaust and intake manifolds together and check with straight edge. Deck flat if needed.
Install gland rings and fit manifolds without gasket for tight fit. Trim gland ring as needed.
Install gasket and torque to 45lbs.
So my questions are what else am I missing?
Is there anything I should look at with the manifolds off, should I pull the side plate and take a look at the valves?
Using copper gaskets, do/don't or sealant?
Hoping everything goods well. thank you.
My check list:
