Replacing door lock on on right door
Eighty
Need to know the procedure for removing and installing new lock barrel on right side door handle of my 1930 2dr sedan. Can not get door handle removed from door. Thanks in advance for your help!
Eighty (A-T)
Remove the 2 door esctcheon screws then turn the handle 45* and pull it out. Some Kroil and wiggling the handle help. I also push the latch flap in as I pull to take a bit of the pressure off.
Thank you Tom, read your directions, went out, removed two screws, and turned 45 degrees, and with a little pressure, came right out. Thanks again, Ford Barners are the greatest.
