Replacing a non 1933 steering wheel - what else fits?
My research and others answers indicate that the 1932 column drop will work on the 33-34 pick up truck dash due to the angle on the bottom side.
Hi Steve,
What other sources confimed that the '32 steering lock assembly was used on the trucks please? Based on the Green book, I thought that was the case but could find nothing to confirm this.
Glenn
As far as what fits, I recently pulled a nice dodge 3 spoke wheel off a '47 ford shaft. It looked like a direct swap and took a tremendous effort to free it.
Steve, It has been awhile since I rebuilt one of these boxes, but it is possible that the bearings are standard as opposed to custom made for this application. Others here on the Barn can chime in on that. I would contact Bearings Specialty, apparently now BSI, and give them the numbers on the races and bearings. Worth a try.
My research and others answers indicate that the 1932 column drop will work on the 33-34 pick up truck dash due to the angle on the bottom side. The passenger style would work if I make a tapered shim to compensate for the truck dash angle versus the nearly straight passenger dash. The information is coming together nicely with the aid of everyone's collective knowledge. Looking like I'll need a steering shaft or an entire box. I will probably run a want add later tonight for the box and column.
Where is everyone buying the upper and lower cones and races for their boxes? I looked at several major dealers catalogs and they are discontinued?
I am posting a picture of a 1934 pickup column drop. It is significantly different than the passenger 33/34 drop. It is also different than the 32 pickup drop. Note how the left side of the drop is taller to accommodate the curvature of the dash on the pickup. The 32 pickup has a 6 inch shorter wheelbase and possibly the geometry is different. I would think that the passenger drop could be adapted using a little ingenuity. I believe the 33/34 pickup drops would be hard to find.
530681
1933 - 34 truck column drops seem to be far & few between available, and searching
through all of the old posts in any of the 4 sale sections there doesn't seem to be any
for sale. The 32 drop is the closest in terms of the actual fit, since the 33-34 truck
dash and the 32 passenger dash are similar. The 32 passenger drop seems to be just a little longer, placing the column down farther in my lap. The 33-34 passenger drop
seems to be adaptable if a large wedge or shim were to be fabricated to compensate
for the differences in the drop to dash angles, so again there are many choices here.
The last of the issues seems to be the column / cover and I haven't located one yet.
What might be the closest replacement, even with modifications to make it fit? Thanks
[QUOTE=steve hackel The 32 passenger drop seems to be just a little longer, placing the column down farther in my lap.
You might need to open up the steering box mounting holes a tad to drop the column down into your lap? Geometry?
After studying this I believe that the setback of the bolt holes is quite different making a passenger drop to work would be iffy!
If your steering gear is good then knock the shaft out of the worm. Any ford column up to 48 can be used by by cutting to the right length and relocating the hole for a lock pin. The switch mount or column drop would need to be correct for the truck.
Just made an example of what you could make for a shim assembly if you ended up using a passenger 33/34 drop. The very top piece in black is to correspond with the shim angle below. It would fit inside of the dash. This allows the bolts to be aligned with the drop. I used aluminum but could be done with any material.
This is the approximate angle I used for a friends universal drop in his 34 pickup.
He was not interested in the "real deal".
530783
YES ! That was my thoughts exactly, and it's probably what I will end up doing
with what am currently faced with. My thanks and your help is greatly appreciated
and it always impresses the amount of knowledge we collectively share.
best wishes, Steve Hackel
I have 34 pickup column drops. I can rebuild you one with a working key. I probably have the column tube as well. I’d have to look. Tim
