alexiskai
Some of you may recall I started a number of threads about troubleshooting a valve problem I had. Here's a summary from the most recent one:
I pulled the head and valves and discovered the culprit: the valve seat on cylinder 2's exhaust was loose. Just sitting in the block, not particularly attached to anything.
So... how do I fix this? I have pretty limited tools and the engine is in the car. I can't deck the block or machine a new seat to 45°. How do I get a new seat that will work out of the box?
Edit: I did check the block for cracks that would have caused the seat to loosen – didn't find anything.
A vacuum test indicated "worn/loose valve guides." A compression test showed 60-65 psi on all cylinders except for cylinder 2, which showed 40 psi on a dry test and 45 on a wet test. A leak-down test on cylinder 2 showed hissing in the exhaust.
