Bobs29ModelA
I have a 1929 Model A Sport Coupe with the standard flathead 4-cylinder engine; however, when the engine was rebuilt by a previous owner, they replaced the standard head with a "C" head, apparently to raise the compression slightly. This "C"-head is equipped with a 3-hole-mount water pump, and the water pump used is different than what the stock cylinder head would have. The water pump used appears to be of the 3-hole type used beginning in 1932, on the "Model B" engines.
This water pump has started to leak out of the packing nut area, yet tightening the nut only seems to make the leak worse. I therefore wanted to replace the entire pump with one of the new "leakless" ones.
In looking at the MAC's online catalog, they have a pump offered for 1932-1934 Model B's, which at least appears to be what I want. However, I need to be sure before I order one. Their part number is "B-8501-LL", and is described as a "Waterpump - Leakless Design - Ford Model B".
Does anyone have any advice as to whether this pump will indeed easily fit the "C"-head? Or, is there another online source that makes a pump specifically designed for the "C"-head?
Any help or advice would be greatly appreciated!
