PeterBo
Over the last few days I have replaced the radiator in my 1929 Model A phaeton. Here in Oz, we get some hot days and last summer I had a few days where 'Betsy' got very close to boiling. I suspect that the radiator then was original and partially clogged. Heat gun on the radiator registered close to 95 - 98 degrees C. with outside temperature of about 34-36 degrees C.
I bought the replacement radiator from Berts (manufactured by Brassworks). Workmanship was impeccable and it fitted into the car with NO issues of sizing or connection to hoses etc. The position of the radiator needed adjustment to correctly adjust the hood but that's expected and was easy to do.
At the same time I installed a new temperature gauge which provides a new sense of confidence. After installing the new radiator the engine appears to be running at about 80 degrees C. I have refilled with 50:50 glycol coolant.
My question to the Forum is whether people have tried the new Evans coolants. Below is a good Youtube video by Jay Leno about it:
https://m.youtube.com/watch?fbclid=...kX25-EWs16W_kEDLjKfAFImOYZNbbnk&v=t7PykrgzWPQ
They claim it is:
- Waterless
- Boiling point of up to 275 degrees F.
- NEVER need replacing
- Suited to no pressure systems like the Model A
- Suited to cast iron blocks
- Not dangerous to animals or environment.
Has anyone used this in their Model A? It seems well suited for anyone with temperature issues.
They claim it is:
- Waterless
