Tom Wesenberg
“I too would stay with the 2 blade aluminum fan. Be cautious and make sure that the taper is correct. A couple of my fellow club members have experienced in-correct taper on the fan causing it to be loose on the shaft.”
“Buy a new aluminum 2 blade fan from a reputable supplier. Some of the early fans had taper problems, balance problems and/or straightness problems.”
I bought an aluminum fan from one of the purveyors of junk a few months ago, but I haven’t mounted it yet. It is dated 10/17/14. Anyone know if it is one of the wobbly ones?
10 years ago I was checking a lot of the aluminum fans, and found problems with blade pitch and the blades not being straight. Over the past few years The aluminum fans I've checked have been excellent.
